JeepCherokeeGuy99
- New Bern, NC
i think he means he pumped it 5 times and then held it while someone opened the bleeder. i hope lol. i hope he knows it takes two people to bleed brakes lol
So, #1, you make sure there are no signs of leakage. That means no use of brake fluid from the reservoir. #2, start vehicle and pump up brakes about 5-10 times and hole down pedal hard. If it goes down steadily, your master cylinder is shot - replace. If it holds, and you still need to pump the brakes to make them work, either your rear brakes are way out of adjustment or you have air in the lines. You've already bled them. Are you confident that you did this right? If so, my best guess at that point is the rear's are out of adjustment. They are supposed to be self adjusting, but that shit freezes up quite a bit, and even after I fixed mine, it seemed like the original self adjusting cable was made too long to adjust properly. The best is to take all this stuff apart (pull the drums off and lube it all up including dia-assembling the adjuster star wheel). But, thru the slots, you can tighten up the free play in the rear brakes which could be taking up more fluid than the stroke of the master cyl can displace. If you never did it before, you probably need to pop off the rear drums and look at everthing.
I'll just copy and past mine from an earlier thread, but this is for an evening bleed, not a morning one.
"That's why you don't bleed them that way. (and I'm not calling you stupid cause I did em that way for MANY years too). Called the kids or the old lady out and told em "pump it up and hold it down", and opened up the bleeder until the pedal went way down. There is a way easier way, but it takes longer. I use it whenever I replace brake cylinders or calipers, but mostly it's just to change the brake fluid, which I do whenever I change shoes or pads. Ideally you change brake fluid at least every other year. If you worked on old cars and saw rusty pistons, you'd know why, but people also say that old brake fluid boils and won't stop you right.
The best way is the GRAVITY method. The only problem is it takes a lot of beer and you don't want to drive right after. (CAUTION: YOU MUST BE 21 TO BLEED YOUR BRAKES THIS WAY!)
1.) Get the car in a position where you can open up the bleeders. I always like to break them loose with a 6 point socket being careful not to break them off. If you can, spray them with breakaway or similar a day before.)
2) Starting with the bleeder futhest away from the master (pass. rear), open it about 1 turn. You can put a little hose and cup on it if you want to keep the old fluid from running all over. Make SURE to keep the master cylinder topped off with fluid and DON'T let it get down to where air gets back into the master cyl. Let it flow this way until the fluid comes out of the bleeder clean. This will take at least 2 cups or so of brake fluid. Using gravity alone, you can drink 2 beers while topping off the master cylinder for the first corner. (CAUTION: Do not store brake fluid in beer cans or put beer into master cyinder. Drinking a little brake fluid however will probably not kill you. Beer in your brake lines might.) Snug up bleeder good when you're done.
3.) Proceed to drivers rear and repeat. It won't take as long because the long brake line has already been purged of the old fluid. So you have to drink your beer faster.
4.) Pass front. Drink even faster.
5.) Drivers front. Etc.
Patience can be substituted for beers, but that's no fun.
This prevents the rubber pieces from going any further than they are used to and self destructing.
:cheers: "
:cheers: "
So, #1, you make sure there are no signs of leakage. That means no use of brake fluid from the reservoir. ... If so, my best guess at that point is the rear's are out of adjustment.
if you still think fluid is an issue...sears does a pressure bleed and flush for 35 bucks....and you really cant beat that.
i hate the idea of paying somebody for something i can do in my garage but thats not a bad price.
come to think of it the drivers rear cylinder did have some seepage when i puched the 2 pistons together to center the new shoes.
i believe i have adjusted the rears correctly. i took the adjuster apart and greased it.
you guys think this might be a good time to upgrade to WJ brakes or others?
