[LEFT said:XJRocket[/LEFT];244183834]Eh I don't think they are exactly the same. I know the hub register is different... I have a 98 Cobra and have tried it. UrbanYan, Can you tell us the hole to hole dimension on the caliper mounts? Thestangis 132mm. Also can you find the hub/rotor offset (back of rotor to back of hat)?
I just checked my drawing of the caliper bracket for you and the Falcon caliper hole spacing is 130 mm.
Falcon rotor diameter is 298 mm, total rotor height is 65 mm, thickness 28 mm, centre hole 71.5 mm
Your Cobra rotor diameter is 330 mm, total rotor height is 43.5 mm, thickness 28 mm, centre hole 71 mm
I am actually thinking of building another kit using those Cobra rotors but with my new set of 4 piston Brembo calipers I have from an SRT.
