88 Wagonman
- Boise, ID
Try removing the electrical connector from the ignition switch and see if it shuts off.
well i just replaced the starter relay and it still wont shut down i have no idea what to do now
i removed a little red wire on a clip from the coil and now the truck works right. when i plug in the battery with the ignition off i get nothing and when i go to turn the ignition i put it to run and the fuel pump kicked on and it started and shut off with the ignition
i cant at the moment but is just a single red wire on a clip. it runs up to the starter relay
Definately need a pic. Have you followed the red wire to see where it goes?it goes into a group of wires the plug into one of the male connectors
