whitneyj
- Mayville, WI
you changed the caster with different c bushings?
whitneyj said:you changed the caster with different c bushings?
Gravesdiggerxj said:so I've set the toe as close to between 0" and 1/32" toe in as I can probably closer 0"
and caster is now set to about 7* and I pulled the steering stabilizer to get a baseline and I still have a pretty significant shimmy above 45mph?
should I try 5* caster and 1/16" toe? Any suggestions would be great.
Tires out of balance will cause a wobble, if yours are showing signs of that I would suspect them as the culprit.
xjeepers2 said:so i am doing the same build and i was wondering did u have any problem with your exhaust pipe getting in the way of the yoke on the front?
Prepmech said:Sounds like it could be the tires. I'm running somewhere around 7* caster, 0" toe, airsoft BBs in my 35s, and have no wobble.
How much airsoft are you running?
I believe I'm at about 12.3oz I was at about 8.2oz, but it wasn't enough.
Your alignment measurements are all within the acceptable range, unless something is worn or loose I would rule that out.
Alignment is set between 0-1/32" toe in, 5* caster (4.5* driveside). Nothing left to be worn or loose.
The issue now is definitely tires. It will run as smooth as glass and if I suddenly speed up or slow down they will run out of balance.
Are you using solid joints on all of your control arms, or do you have some bushings in there? I'm wondering if the single upper control arm is having difficulty controling the caster.
Rubber on the driveside upper, solid joints everywhere else.
tayman said:hey, wait a minute... didn't I already say that?
Brian just got a mudflap ticket too: B-Town is cracking down on us non-mudflap criminals :nono:. Did you go to the car show?slcpunk74 said:thats funny I just did my mudflaps too because I got a ticket. My mount was very much less cool but with the jeepspeed its been busy times... I got some hannemans put on the jeepspeed ;well they are painted and setting on it ha ha
