outlander
- Columbus,Ohio
I honestly felt that much of a difference with the truck plugs and big wires(really couldn't believe it myself)........YMMV
I'm with you on the aftermarket ignition systems, but do you really think you can feel the difference between spark plugs and wires? It takes a fair amount of power increase to actually be able to feel it. Sounds like the placebo effect to me. Not a big deal, if you do, you do.
Like someone just said, if the spark ignites the mixture, then the mixture is ignited. Unlike a diesel, a gas engine is sensitive to the air/fuel ratio, and once it explodes, it explodes. The explosion will ignite more in the cylinder than another spark will, plus with an explosion it all happens at once. Again, gas is not like diesel, diesel burns and keeps expanding as the piston goes down, but a gas engine has one ignition event so one explosion expands the gasses that push the piston down, once it's exploded, it's exploded. Don't see what a second spark would do, unless the engine is so worn out or out of tune that the first spark didn't always ignite the mixture.
The XJ coil puts out over 100,000 volts, as do all modern coils, unlike old coils that put out around 36,000 volts. You can improve on 36k volts, but it's damn hard to improve on 100+k volts. That mixture is going to ignite unless there's something else wrong.
I think the proposition that if the spark ignites, it explodes is sound. The point of a CD ignition is to make absolutely sure there is a spark that can ignite a continuing oxidation reaction.
Combustion chambers aren't static or homogeneous. Deliberate swirl designs, the forced draft of the quench chamber contracting to a few ten thousandths, and the continued induction from the closing valve and it's own movement, plus the rapidly slowing piston itself all produce turbulence - which can and does snuff the initial flame front. That's called a misfire - a common complaint in all motors.
When the quickly compressing gas mixture is inadvertently ignited, ping, dieseling, and other uncontrolled flame propagation occurs - some of which is potentially damaging. That's specifically why CD ignitions were developed for on the edge, less than optimum combustion chambered engines - especially those used in racing.
Not necessarily the 4.0's main purpose in life - but in a motor with more than 150k - and there are lots of them now - carbon deposits and less than optimum induction in the ugly log manifolds Chryco abandoned may be reason enough to add the system.
Once the spark has ignited the mixture, sure, it should explode - but it doesn't always do that. So plug makers jumped on multispark plugs - split electrodes, multi electrodes, surface gap plugs, the diamond hole electrode plugs, and now, capacitor discharge plugs - plugs that fire multiple times.
Aside from upping the amperage beyond safe limits, multiple spark discharge is exactly what "Detroit" is avoiding. I believe it's because they can get results cheap with a standard coil and plug.
Kinda like adding an air pump was cheaper than building the engine to closer tolerances.
