Motor mount install
dhreeves
Aurora
I just installed new motor mounts in my '87 today and changed the 3 oil filter adaptor o-rings since I had it off anyway. All in all it was an easier job than I expected. I would recommend you replace yours before they get this bad....:doh:
Did you use the "jack under the oil pan" method? The easy way i would call it. I need to do mine REAL bad!
those are not as bad as they get! I could not keep stockers in mine. more to the rescue!
Yeah, jack under the oil pan and no stockers here either. I went the the Brown Dog rubber mounts. I'm quite happy with them so far.
Mine are worse then that, and still holding my engine "up". I can fit one to two fingers between the top and the rubber.
~Scott
i did mine a year ago along with an apn headder. the m/m were way too easy. definetly nothing to be intimidated by.
