modifying the front suspension
Sherman_thetank
Keep it pinned!
omaha, NE
Ok, my question is what will be the downfalls and problems i will have if i remove the upper control arm on the passenger side? the mount is in the way of my exhaust, and i need to be able to drive it before i swap all the crap out to leaf springs. I no it will change the whole geometry of it, but i dont see it making a huge difference :dunno:
Thanks.
Are you talking temporary for one or two drives, or longer?
People here have driven on 3 control arms when tacoing one (myself included) but I'd stick to 4 for as long as possible before the swap.
I drove on 3 control arms for the better part of 20 miles without realizing it. I spent the whole time going "I wonder what that funny crunching noise was... ahhh crap, there it is again when I braked. I bet I blew up my darn shocks or sway bar links again. Oh well, I'll deal with it when I get home." Got home and realized I ripped my passenger LCA bracket off the axle housing.
Not to say it's a good idea, but go easy on the skinny pedal/brakes/turning, keep it in RWD so the axle is mostly just rolling, and you should be ok.
It it would be for long, just driving around my circle a little bit to test the new motor ar tranny a little, and then it would have to go about 20miles on the highway to my new apartment, but it sounds like it shouldn't be a real big issue
If you have stock upper arms, don't do it. If you have a really beefy aftermarket arm you can weld the axle tube to the diff housing on both sides and fabricate a new upper control arm mount for the drivers frame side and you should be O.K.
So from what your saying it could twist the axle housing? I guess i can see how that could happen...hmm that puts a different spin on things
