B.RAIDER
- Central Texas
LOL...I here ya there.........Now, to find the right substitute.
Good Idea.......is there a part number for the sensor that gets moved there?
Thanks.............Well, I'm going to hunt up a list of possibles, then give the list to my Son so he can use the Alldata at the dealership to check resistance values. However, my bet would be that the 91-95 Wrangler would be close.
The pictures that I have seen on the net show some kind of ceramic looking end that's in the manifold itself. Mine is disintegrated.One other thing is that the MAT is in the plenum so it will get coated with blowby or any unfiltered air that makes it into the manifold (ie vacuum leak) and the likelihood of a bad MAT gets higher every year.
Can't get the MAT sensor...just found out a little bit ago from the dealer....none of the other auto parts places can get it either. JY will be my only option there.
No manifold leak either (none that we could tell anyways), mechanic sprayed it with something in a aerosol can to see if injectors were leaking and checked the manifold also.
The last thing i have not checked is the O2 sensor. That's next.
They list for $50 bucks here....is there any generic O2 sensors that would work?
Question there is, would they be compatable?Here is a generic MAT that may do the job from a post by 5-90 in another thread on Renix parts:
http://www.injector.com/sensors.php
Thanks for the info..........Well, the resistance numbers are very close, could be worth a shot if one can't be located in the salvage yard.
Where can I find the resistance numbers to the OEM sensors?
I have been on google and haven't hit the right search words yet, I guess.
Mopar # 33002382 intake manifold sensorAlso interested in part number.
Got it Thanks....Check your e-mails!! aperwork
So your saying I can use a coolant temp sensor in the MAT's sensors place?I think this is/was the NAPA part number for the MAT or ACT sensor;
Item#: DEMTS10192
So your saying I can use a coolant temp sensor in it's place?
