I haven't added antifreeze yet - I wanted to see if the coolant tank needed refilling, which would indicate I still had a leak. I also didn't want more antifreeze in the oil if it was. I definitely plan on adding a/f long before winter.
I used the hd glass seal product alone, according to directions. That means flushing the system clean, which involves popping the lower hose, which involves removing the air cleaner, etc. It's messy. I wanted to see how it worked, if it did. It apparently has. I have used a polymer sealer before - Dike from Conklin, and I know it can do the same. I was out. It's available from any Conklin dealer or Speedway. It's sealed serious head gasket leaks, and even sealed a rusted out freeze plug behind the flywheel for two years. When that starting leaking again, I found a quarter sized plug of green in the shell. The biggest piece I got out was the ring.
My lifters don't rattle now, an occasional tick at idle. I'm considering moving up to a 15-40w - but I'll wait for the 5k oil change now.
