Built2Flex
- d
Anyone switch over to manual brakes? I'm currently in the process and I'm having some troubles. I'm attempting to use dual 3/4" master cylinders and the factory pedal assembly. I have discs on all four corners, 3/16" hardlines and #4 stainless soft at the calipers. I'm wondering if I need to increase the bore size to 1". I'm also wondering what pedal ratio others are running. I believe the factory is 6:1. But if you've switch over to manual brakes, did you adjust the ratio? Thanks in advance although I don't believe many have done this.
