TRCM
- Newport News,VA
The only solution to clear some space is to move front the radiator.maybe with this and with the shroud from a 4 liter xj have some good result...
Ok, not sure what you are saying, but it seems like you want to put the fan in front of the radiator, with the shroud in back....that won't work.
The shroud needs to be on the same side as the fan, and any shroud should be behind the radiator, not in front of it
if you are moving the radiator so you can put the fan behind it like normal, that might work then
