- Bakersfield, CA
just for clarity, are the JKS adapters mickey mouse too? and yes i admit this would have been a booty fab workaround.
but moving on...
are the shocks ends on heim end shocks bigger than bushing end shocks?
No, the JKS or the T & J upper shock adapters are not mickey mouse. However, they are both hard mounted to the body, and simply convert the hole for the stem mount to a bushing mount. It doesn't convert the shock, it converts the mount, then you use a bushing shock.
Nearly all higher end shocks come with heim joint ends. I think the non coil-over shocks, like 7100's, the ends are a little smaller than bushings, but all of the coil-over shocks and air shocks the ends are bigger because it isn't a heim joint on the end, it's an aluminum housing end that has a uniball (like a heim joint) pressed into the housing.
