MachineMan
- San Jose, CA
I have the same low voltage gauge issue. It must be a global problem and I've seen several threads about this. I have a 145amp alt with optima. Replaced positive relay wire with 4ga, added a battery to chassis ground 4ga, added a Alt to ground 4ga, replaced the Alt positive to relay with 4ga. When idleing the voltage across my battery is 14v+ volts strong while the inside guage is around 12v or so with no accessories running. So the question is, where does the gauge tap into? And can it be wired to a more representative source....
