nrwphoto
- Appleton, WI
Yes, everything was finger tight on jack stands and torqued sitting on all 4 tires. I have even broke them loose and retorqued. Which was after a 200 mile day trip which I discovered the DW on.
At this point pretty much everything on my Jeeps front end is new or replaced in the last couple years. Everything is tight and/or torqued properly with no movement to be found anywhere. And I have had it checked out by a local mechanic I have been taking the Jeep to for the P.I.T.A. repairs for several years. He did a laser wheel alignment and thought it all looked good.
So after inspecting, road testing and plenty of thinking it is that over designed oval bushing at the rear of the control arm. The sleeve for the mounting bolt goes through what I refer to as a web in the bushing. Solid rubber on the top and bottom, but those crescent cut outs in front and behind the sleeve. This design worked fine on my Jeep at factory ride height. But at the angle it currently sits because of the lift it is causing the axle to move back and forth on bumps.
My DW happens when I hit a bump on only one side or if I go over a poorly lined up expansion joint that is at an angle, going onto or off the local bridges. Basically one side hits the joint first. In either case those crescent cut outs in the oval bushings are allowing my axle to move backwards a little and then rebounding. If it hits the right harmonic then DW ensues.
Another factor in narrowing this down is that I have found virtually no one that has had DW appear immediately after installing the OME lift on an XJ. However I have found a half dozen or so people who have had DW appear on their WJ right after a similar OME install. 1 of the few items my XJ and a stock WJ have in common are those LCAs.
So the theory is that at factory angles the oval bushing and suspension works fine dampening road noise and vibration. When you hit a bump the suspension moves up absorbing the impact. However get that LCA at just the wrong angle as you are going down the road and some of the impact when you hit a bump is transmitted rearward instead of up and (again those over engineered cut outs on the oval bushings) allows the axle to move rearward just that fraction of an inch which then amplifies into the dreaded DW.
I have the same setup. The control arms are beef, and well designed.
They allow quite a bit of length adjustment. Grease ports are a nice feature too.
And made in the USA :us:
Do those JKS arms clear the shock mount braket alright at full droop?
When was the last time you changed the upper control arm bushings at the axle? They are pretty worthless and can develop slop easily
Hmm. Interesting.
Be sure and post results with the new arms!
I'm running WJ arms on mine at stock height and will be curious to see what I can expect or what to look out for when I lift it.
Did it fix the DW?
Well, I won't ask you to put the WJ arms back in but with two problems found on the upper control arms it's hard to pin it exclusively on the lowers. I'm glad the problem seems fixed, though!
If I were to spend money on stock-ish (basically non-mid/long arms) I would go with Tnt or clayton.
I am not interested in the most expensive, I am looking for the best quality I can find. Plus the JKS arms are not offset at the front bushing or curved to clear the shock mount.
odd recommendation wasn't it?
After having installed several short arm lifts, changed many springs, and spent countless hours dialing in pinion angles, there is only one set of arms I will recommend.
Savvy OffRoad.
The double adjustable uppers make dialing pinion angle and setting caster much less of a headache.
Do yourself a favor and don't cheap out on your suspension.
