stephenspann27
- College Station, Tx
Do you have a vacuum disconnect on your front axle? If so you can weld your front spiders too and whenever the vacuum disconnect is disconnected you will have two wheels that can spin at different speeds then when you lock the disconnect the axle will be solid just like it you had a spool.
What is the downside to doing this? I have an '87 with a disco 30.. and have wondered about doing this. Would the downside be that the carrier and front drive shaft will now spin even in 2wd? And loose the part wear/fuel savings?
