Ok. For your wife it's cheaper.
I got my wife talked into leaving on Tuesday, so we'll be there Tuesday afternoon.
sweet.
We'll be there weds. afternoon.
When you put the new windshield in, put a 97+ gasket/trim on instead of the early style.
Pops the blower fuse anytime you use an AC setting on the vent position. Runs all speeds fine in the vent/heat.
I know what you're thinking, a short in an AMC dash? GTFO. never happens. ever.
and the windshield leaks.
Pretty happy with the Falkens for daily driving.
I'd bet it's a bad AC pressure switch on the receiver/dryer. Pull the plug on the pressure switch and try again.
likely, the switch was unplugged under hood. It got plugged back in and that's when I notced the blower not working on the drive home. I think I'm going to have the AC professionally charged and converted to 134. THis thing still has pressure and R12 in it.
Check the windshield frame for rust.
If it's there at least it's not bubbled out to the roof. I can fix the flange bit
Wildpeak AT? My new set did well on my little Jeep in Death Valley, held on well at 50 mph on gravel/dirt/washboard, too.
Rocky Mountain AT
It's the discount tire named one so they don't have to price match. Appears to be identical. Aside from the holding rocks and flinging them at 50 MPH they seem to be pretty good. I had it in the wet yard and no tire slip. 2 low may have had something to do with that. Speaking of, I'd never seen the use for a 2 low kit, but it could be handy as hell with a 5 speed jeep.
Makes for some wicked burnouts too.
the burnout I did the day we made it driveable is the last one it will ever do.
Rocky Mountain AT
I don't believe you.
Commuting in rush hour traffic I wish I had one every day. So does my clutch.
If only it was easier to get 2lo working without spending a mint on the kit.
(I really just wish I had a dana 300...)
believe it. I drive like an 80 year old man on sunday.
I only abuse things in rocks.
Remind me to never get stuck behind you in traffic.
good call on this. unplugged it this morning, now all of the vent selections work on all blower speeds.
I'm going to rehab the AC system with a new drier, pressure switch and seals. I figure I'll have someone evacuate it, then I can do all the work, and I'll take it back to have it properly charged.
I didn't know you moved to California.
I'm a 5-10 over speeder... stay right except to pass and I won't spit in your beer :gee:
Get yourself a vacuum pump and do it yourself. It's really pretty easy.
Oh, and you might consider substituting R152 instead of paying out the ass for R12. R152 = modern computer air duster. All you need is a can tap to use it.
I sent you a link via facebook with info about using R152 in automotive R12 aircon systems and the various procedures to vacuum and charge a system.
