Sweet, I just used a coat hanger to set mine thanks...also you seem to be missing your e-brake
yeah. I've already gotten all the replacement cables. 16 bucks to my door.
Forgot to grab the equalizer from Doug's garage that came from the 87.
no worries. I wasn't gonna mess with it until I did the axle swap anyhow. I just found a wheel chock shaped rock and rock that.:laugh:
I hope you didn't buy Dorman cables, they're crap. On the other hand, the Raybestos cables I just put on my XJ are pretty good quality.yeah. I've already gotten all the replacement cables. 16 bucks to my door.
I've already robbed these from the limited in the yard.
Really good shape, all the power base stuff still works because I powered them with a 4S LiPO in the yard so I could get at the rear seat bolts:
This sounds like a cool trick, can you explain how it works? I had to pass on a set of WJ seats once because I couldn't get the seat to move to access the bolts.
Nice MJ, great to see another one being saved.
The connector coming directly out of the motor is a simple power/ground. You just need to jumper it to your battery of choice. I used a 20v cordless drill battery a couple weeks ago.
If it goes the wrong way, switch the polarity.
the 12V connection going to the seat base switch is underneath and goes under the carpet.
Cut it, shove wires to anything approximating 12V, use seat switch to check base. a 4s lipo is 15V. I happened to have my flight box in the car with batteries. like redheep said, a cordless drill battery works too.
