RichP
- Effort, Pa
Building a 01 TJ for a friend, the lift is 12", long arm front and 4 link long arm in the rear. 38's and using 24" shocks. The rear will droop alot more in fact I needed to raise the lift 4ft before the unshocked tires started coming off the ground. I want to put limiting straps on it, keep in mind this is a TJ so it's got a frame. Problem is I never did one this tall before and never ventured into the land of limiting straps so I've got nothing. I'm also pulling my hair out trying to find a 36" long stainless steel flex line for the rear brakes or I'm going to end up with a rather interesting combination of hard brake line and a couple of short 'flexable' lines running up one of the long arms.:anon:
