Lift question. An odd one thats driving me nuts!
Fixn2xlr8
Earf
I installed a rustys 3" lift. Full leaf pack over the winter. I gave it PLENTY of time to settle.
Drivers side measures a 4" lift. Pass side measures a 3" lift. You can tell dead on that its tilted ever so slightly.
Stock steering, sway removed. No I dont have a fat girl friend.
Ideas?
Was I sold a 4" lift by mistake and havent accounted for the extra inch causing it to bind up?
Most springs sit slightly taller than advertised at first/for a while.
Is both front and rear on that side sagging? For front, you can either get a 1" coil spacer to even the front out, or if you want a bit more lift in the front, maybe get a pair of JKS ACOS, then you can adjust/fine tune the front height.
