My keyfob recently when pressing the lock button the horn used to beep 1 time and now it doesn't my horn does work if pressed and if I press the panic button it will go off...Anyone?
This should probably be in OEM tech... (unless it's an aftermarket alarm, I guess)
I think it's a config issue, I recall there being some way to change this setting by pushing and holding certain buttons. A little searching should find the answer, there was a thread about it in the last two weeks.
