xalexjx
- Newcomb, NY
Ok, the current dana 44 in the front isnt cutting the cake(a narrowed powerwagon axle made by currie, uses jeep width 30 spline shafts), the ring and pinion are almost ready to fall out
New front axle build
79 ford f-250 High pinion dana 44
cutting it down to jeep width
butt weld jeep knuckles onto it to retain stock jeep, brakes, bolt pattern ect
gear it to 5:43 to match the back axle with an OX locker
run my chromolly shafts outta my current axle with CTM'S
Weld on some tj brackets and install.
the axle tubes on the full size d44 over the d30 are not even comparable.
new front axle, cut to width almost
dana 44 vs dana 30
CUTTING
inner c's getting ready to be welded, jeep stock width
inner c's butt welded on, inside and out, they shouldn't be coming off
Half of the mounts are on
dana 44 vs dana 30
CUTTING
