Hello Guys ,
have 2000 sport XJ AT ,with 32" wheels with a lift
today while driving when shifting to R the jeep dies ,the RPM goes to 0 and it shuts down
it happen twice both on a incline ground (upwards)
after that it drove fine ,at home connected the scanner and found these codes
p0743 1-2/4-5 solenoid circuit
p0753 TCC solenoid circuit
p0756 Shift solenoid 2 functional performance
p0740 TCC out of range
I live in Dubai ,and its really hot in here so i believe the transmission had good amount of heat.
a month ago had the jeep not shifting to OD ,then ordered set of 3 solenoids and replaced them all with filter and fluid ,then its driving normal and shifting fine to all gears.
what does these codes means if the Jeep is running fine ?
