XJRocket
- Beaverton, OR
Wow, what a deal!! Congrats man.
I rather a regular IC as well, but I have no clue where I would put one (like I said before, I don't like clutter). Also, wouldn't a core within your intake push your SC out too far from the engine?
That is one option. I need to get my hands on one at least for test fitting as the input line may be pointing in the wrong direction.2.5L 4-cyl pumps bolt on and have a remote reservoir from the factory.
probably something to do with the tensioner setup changes, I know on the 4.0 the old style tensioner with a 2 bolt PS pump was used till 95 and the new style with a 3 bolt PS pump was used 96 and later. I don't really know much about 4cyl jeeps, but my money's on this, either PSC has the year split off by one or chrysler changed the 4cyl's tensioner/PS pump configuration one year earlier than the 6cyl.I could mount the reservoir to the front of the SC utilizing the snout bolts. Driver's side would probably work best. Another option is make a mount off the SC snout bracket. It will be nearly directly over the PS pump.
The only problem I see with the 2.5L pump and YJ pump is that the inlet points down and forward, which may cause an issue in hose routing. For cross over years PSC's kit states 95-06 TJ 2.5L/4.0L and XJ. So, pre 95 there may be something different about the pumps. PSC also has a pretty good PDF on reservoir mounting tips: http://www.pscmotorsports.com/pdf/tech/reservoir_tips.pdf
Deleted, OP already said he looked at PSC stuff... My bad.
Actually, that brings up a good point. That mount doesn't follow some of their recommendations in their reservoir mount PDF. "2. It is preferable to mount the reservoir directly over the pump. If this is not possible, in front of the pump is typically better than behind it." Behind the pump; "2. It is preferable to mount the reservoir directly over the pump. If this is not possible, in front of the pump is typically better than behind it." and "It should not exceed 16 inches." Quite a bit over 16 inches in that positions. It also wouldn't take much of a hill to put the pump above the reservoir.
I've also seen discussions about the possible merits of running a slightly pressurized reservoir for the steering to help prevent cavitation and fluid starvation...'industry' guys have mixed opinions on whether a vented reservoir or a sealed one is OK. Just more food for thought.
