lifted00
- Charleston, WV
I fought and fought trying to find this leak. I finally found water leaking between the window and weatherstrip belt. But by looking at the pictures of the bottom of the door it appears that there are drain holes. Is water suppose to seep in there if these are drain holes? The water seems to be leaking thru the widow seal and finding a path between the door and door panel then soaking my passenger side floor board.
