- Reno, NV
I had swapped out my XJ knuckles with WJ knuckles and brakes but had been running my existing Currie steering setup, and had been waiting awhile for my Ironman4x4Fab steering setup to arrive. When it finally did, my buddy Dennis and I went to work on swapping over to the new setup. I am running a G2 Core44 front axle, so I knew some modifications would be needed to the kit to make everything work correctly.
I ordered the over knuckle WJ swap kit with the offset track bar bracket as well as tie rod ends - which I later found out was a good decision! There is no way the tie rod would work with their track bar bracket, without off set tie rod ends on my Dana 44.
All the components of the kit -
The first thing we had to do is cut off the old track bar bracket, so we could begin to fit the new one. The G2 axle has a slightly different configuration than stock with some extra cross bracing -
We cut off all of the old track bar mount as well as the old steering stabilizer bracing. We cut a little at a time to see if we could tie in any of the old stuff to the new bracket, but eventually had to just cut it all off.
The new track bar bracket has an alignment hole that lines up with the old track bar bracket inner mounting hole - so you know where it is suppose to go on the axle. The new axle side track bar mount has multiple mounting holes for the track bar, one thing we quickly realized is that with my axle, the bracket hit the spring so we would have to clearance the bracket where it hit the spring so the back mounting holes could not be used.
Here is the bracket mocked up -
You can see here how we cut the bracket to make it clear the coil as well as added cross bracing support -
