spencer elliott
- St. Louis
I have them. Very beefy. They are long, though. At the shortest length they gave me about 2" lift.
Did they come with something to protect the exposed threads?
If I had those and there were threads exposed I would probably slather those threads with Green Grease and split a hose to wrap around and zip-tie in place.
I think I just found a new sig! LOLCant you just coat them with a thick layer of vaseline?
Are you sure you have the same shackles? The website lists them as being for 0 to 3.5 inches lift.
i think im going to be combining these shackles along with some JKS ACOS. match that with the 3" kit of my choice and some long arms and ive got a fully adjustable kit with a range of 4-7.5".
so im thinking that then i can throw some 33's on my 01 and adjust the height accordingly from there.
now which long arms to buy... thinking either claytons or BDS
I would use the ACOS to maintain desired ride height once weight is added. If you do not plan on adding weight then just run a coil for the desired height.
Reason ACOS $200+ vs. Coil Springs $80-100
