Justpunchit
NAXJA Member #1291
- Jaffrey, NH
I'm going to sleeve my hp non disco d30 housing alot like this after market kit linked here...
http://www.rockslideengineering.com/servlet/the-9/R-dsh-SE-Inner-Axle-Housing/Detail
The question I have is with the axle seals, do I run the tube all the way down to to the inside edge of the diff housing? If I did do that then I'd need to run a different seal due to the smaller ID of the axle tube, if I leave the sleeve short to run a stock seal it's going to be a real problem getting in there to weld that end, and I don't know if I'm compromising the strength of it.of course on there site there are no measurements and I definitely don't want to call up and ask how to copy there product but I'm kinda not sure how it should be done.
Also should I drill out plug weld holes in the axle housing to ensure it stays put? Like Poly performance's JK inner sleeve kit?
