In a proud tradition...
OD-XJ said:
That's looking pretty good Eli! Can you post up a bigger picture of your grooved tire? I want to see how you did yours. Are they regular TSL's?
I'm really envious of you guys. I wish I could go :mad:
-Jeremy
Thanks, Its getting there.
Here's a thread I did on the tires a while ago, they are the same way now. Seems to work well, plus it gives you 3 center lugs, instead of 2(If you cut them in the middle). http://www.naxja.org/forum/showthread.php?t=929503
They are regular bias ply TSL's. If they make an SX in a 33x12.50x15, Id run them instead. These are plenty strong anyways.
Like everyone's said, catch a ride homie.
I wish I could make it but its not in the cards this year. I will be on the west coast early next month but wont be ready for a trail for atleast a month.
(the other)Jeremy
Matt_West said:
1. Install Thor Guards (DONE)
2. Replace lower radiator hose (DONE)
3. Power Steering cooler (Not happening)
4. Transmission cooler (Not happening)
5. CB (Doubtful) (DONE)
6. Radio antenna (Doubtful) (Not happening)
7. Cut rear quarters (Not happening)
8. Move spare to different rim (DONE)
9. Fix drivers side window (DONE)
10. Battery clamps (Wood screw) :doh:
11. Check dog into Camp Happy Paws Tomorrow
Added: Christy helped me out so some things not on the list were done. Tie downs, painted trim, painted bumper, cleaned Jeep
CanMan said:
Got to make rear seatbelt tabs off the cage,
install 2 more speakers,
adjust half door hinges,
cover hole above muffler on floorboard,
adjust E brake,
and a few other small things Im sure Im forgetting.
Done, in and bolted.
Done, quick removal from rear hatch.
Will do that tomorrow at work.
Done with license plate.
Done, but need to adjust shoes inside rotor.
:dunno: on the few small things.
my THORs are painted
Update:
My list: (hope I can get it done so I can meet some of you guys!)
- clean and grease all electrical connections (done!!)
- adjust TPS (done! will recheck)
- install new t-case drop (ran into problems, will finish tomorrow, I guess it is today now...)
- brake and e-brake check (today)
- spare mounted (today)
- relocate the o2 sensor (today)
- lightly sand and repaint rims (today)
- radiator flush (today)
- install CB and antenna (today)
- check grounds (done)
- oil change (done)
- check spark plugs (done)
- install differential guards (friday)
- mount front tow hooks (friday)
- nutserts for bushwackers (today)
Let's see if it all gets done......
ethernet said:
All that work to go wheel with you guys and one phone call changes everything...
Dispatched called. I am headed out on the fireline!!!
that sucks, stay safe so you can wheel another time.
Doesn't suck actually. Making $15 and hour and working 90 hours a week is really nice. Especially the 50 hours of OT!! More money for wheeling! :D Safety is number one!
