In a proud tradition...
Damn Joe, wish my girlfriend would get out there and work on my junk. She works on my 'other junk' though. ;)
-Finish half cage
-Get 2 new tires, and groove them
-Fill up tank
-Gather up spares
-Install rear seat
-Install rock lights
-Some more small stuff
Short list for me:
1. Tires (will be done this Friday).
2. Install CB.
3. Buy 12 cases of oil for the trip. :twak:
-i
Updated list... Urg...
My list: (hope I can get it done so I can meet some of you guys!)
- clean and grease all electrical connections (done!!)
- adjust TPS (someone coming Tuesday to help me)
- install new t-case drop (planned to be installed tomorrow)
- brake and e-brake check (wednesday)
- spare mounted (wednesday)
- relocate the o2 sensor (exhaust shop to do once able to drive, thursday?)
- hold downs for hi-lift and co2 tank
- install CB and antenna
- lightly sand and repaint rims
- fire extinguisher
- gas can
- radiator flush (tomorrow)
- check grounds (tomorrow)
- oil change (tomorrow)
- check spark plugs (tomorrow)
buy
- rock rails (not gunna be done for NW Fest... :'( )
- front and rear diff guard? (ordered)
- 4.56 gears (dreaming)
- front recovery hooks (ordered)
- regulator (hmmm... brithday is Tuesday...)
- bolts for bushwackers
- fire extinguisher
- gas can
buy
I have some stock bushshitter bolts...
-Alex
Nah I don't want the stock ones. Since they are self tapping. I am going to get some actual bolts and nuts so that I can take my front bushwackers off when I go wheeling.
I used to use the stock bolts with nuts on the back side, worked great.
-Alex
-Alex
I couldn't, well, not me, the people at Fasteners couldn't find a nut to fit the self tapping screws.... Maybe I will try that again...
ethernet said:
haha... the legallity issues for when i drive on the road around town... i know... it sucks... :D can't say i haven't done if before however...
any ideas on how to do it though?
If you welded the nuts to the back side of the fender you could just un due them from the outside.
If you don't have the ability to weld, you could "cold weld them" that would probably work if you preped the area good enough.
If you were to do this, I would recommend putting additional support under the nuts (either large washers or better yet a strip of steel with the nuts attached on the back.
Michael
My last update (I won't be working on the Jeep anymore before NW Fest).
2xtreme said:
Here is my list of expected mods prior to NW Fest for the XJ:
1. Build Rear tube fenders and light guards (Done)
2. Install all new Heims in Steering (Done)
3. Mount and Install H1 Double Beadlocks (Done)
4. New bellypan and Engine/Tranny skids (Done)
5. Install 2Low kit (won't be done for NW Fest)
6. Finish building and wire folding light mount for Exo Cage (Installed but not wired yet)
Other:
1. Install CB in tow rig (decided not to do this yet, won't really need it for NW Fest anyway)
Michael
-Finish half cage
-Fill up tank
-Gather up spares
-Install rear seat
Half cage.
New tires. Grooved. Damn, small pics. Camera phone took em.
Gas tank full.
Spares gathered.
Rear seat in.
Rock lights in/replaced (old ones burnt out).
Also added a PS cooler.
Got to make rear seatbelt tabs off the cage, install 2 more speakers, adjust half door hinges, cover hole above muffler on floorboard, adjust E brake, and a few other small things Im sure Im forgetting.
That's looking pretty good Eli! Can you post up a bigger picture of your grooved tire? I want to see how you did yours. Are they regular TSL's?
I'm really envious of you guys. I wish I could go :mad:
-Jeremy
-Jeremy
I still say you should just show up, we'll find you a seat!
You can ride with me, Jeremy. Sounds like you've got more issues going than just the XJ not being ready though, so it's all good.
PM me if you want to ride over and hit the trails with me. I'm leaving early Friday morning.
