back to the pic with the three gay dudes in the water.
can anyone identify the object seen underneath SeanR?
was that expelled from his bowels?
Sam before they fire you start wearing gay pride shit into work, that way when they fire you you can go after them.
Im going to be at the badlands sept 22nd for my moab shake down pre-run.
mac ‘5 weeks’ gyvr
Cliff,
What do my service records say for the AC system? Should be logged somewhere. I wouldn’t mess with it personally If it isn’t leaking. The fins coming out isn’t critical as it just directs air flow past the actual coils. That’s why when I swapped engines and did all the frame and bumper work the condenser stayed....
In other news.
I bought Btaylors XJ tonight. Just got home with it. Drove right past go slow Brad’s house and laid on the horn. Only knew it once I was past it after seeing his XJ in the garage though. Sweet FSJ though brad.
Anyone up for a badlands trip. Need a shakedown run sometime before you guys leave for MOAB right?
Cliff,
In other news.
i'll be at badlands next weekend with a bunch of MJs
Next weekend as in the weekend of the 25th?
correct. i can only wheel on saturday the 25th but i think others will be there fri-sun
I had wanted to upgrade the braking system before the next trip, but not sure if I will have time to tackle that or not. Rear discs and master cylinder and booster off of a 95. Just have to pick up the longer wheel studs, discs and pads and find a couple hours of time...
No worries on the AC i just have a bad memory if i did anything to it. Hints the logs so i don't do it twice lol. If you don't use it yanking it would free up some air flow and you could run onboard air with the compressor or bypass it.
I don't use it really, but it sure is nice on those random days it is hot and raining!
I am leaning towards ripping it out and gaining from the additional air flow and then using the compressor for on board air.
You need to go. I may need a seat!I don't use it really, but it sure is nice on those random days it is hot and raining!
