POLAR_JEEP_04
- Ohio
What guy?
Free shipping = they do nothing I'm assuming.
If any of you Wisconsin peeps make it over to the airshow in Oshkosh this year, you might see an ugly fat guy in a flight suit with a couple of V22's. I bet he can get you a good tour.
Im pretty sure those tires have a recall on them right now for the belts popping through the tread. I can try and find the recall tomorrow at work. Just something to think about.
What are you guys running for gear oil with your lockers? I have some noise coming from my rear axle I just put under the jeep this spring... I do not have much info on the axle from the PO as he bought it built and never used it... 8.8 with an ARB and 4.88 gears... Most noise when letting off the throttle... Can't decide if its shims, oil, or if the bearings need to be replaced...
Pull it apart and look?
mac 'or have your kids do it' gyvr
check the LTX M/S 2 please. I have them on the 'hoe
thanks
Luckily I bought shims for my old 8.8 so I should have plenty if I need to re-shim anything
