The front cover leaks at the corners and sometimes isn't noticed. If it smells like antifreeze, it's leaking from somewhere...big or small. If it's been running at 230 degrees for a while...it probably has a small leak or two.
The driver's side door is probably a mess, or has been fixed by a hack job or two. The bushings wear out at the door pins, all is replaceable. The door sags and kills the door latch, you can fix all that with time and patience.
If the front axle bearings haven't been replaced, they are probably junk on the case, but at 230k, they have surely been replaced.
The heated seats likely don't work. The rear wiper arm is probably gone.
They don't typically rust to bad, even up here. Usually just the rear hatch.
Hopefully the intake gasket was done long ago.
mac 'let me know, I'll be up around noon tomorrow' gyvr
