Kevinma255
- West Milford, nj
If after a charge it is still weak I would tend to agree that it is the starter. check ground straps and make sure connections are clean first, If they are try turrning on the headlights (with somone watching), then crank it. if the lights get very dim you either have a bad battery or the starter is drawing too much power. they should dim just not to almost nothing. the proper way to check it is a load tester but you would have done that if you had one.
