- Hammertown, USA
rustysxj said:would it be easier for me to buy a 3 inch lift, and later go and put 1.5" coil spacers/shackles?
No. a "3 inch lift" - pretty much all of them, come with lower control arms, front coils, some kind of rear lift (aal or leaf pack) and MAYBE a rear extended brake line.
a 4.5" lift comes with all of that, plus front brake lines, trackbar, upper control arms, a transfer case drop (that you will not use, needing an SYE) and some kind of swaybar disconnect or extension.
If you buy a 3" lift and want to go to 4.5", you pretty much are buying a new lift kit. You can buy the RE 3.5" lift, add the HD trackbar to it, and run that for now. That lift comes with exactly what I listed above. Whe you want to go bigger, add front brake lines, upper control arms, a rear shackle, and a spacer up front. You probably still need an SYE at 3.5" on a late model though - some people dont, some do, theres no real forumla.
If you want, PM me and I'll drop you my phone number. I've lifted about nine xj's in the last two years, on top of running mine without about six different lifts and suspension config's. I'll give you an hour or so to ask me every possible question you can think of, and will give you the most honest answers I can.
-Cal
