Ignition Lock Cylinder Removal
Taggdog
Pa
Ok, so far this forum has been Great with the info on how to release the ignition lock cylinder on my 2000 XJ Sport. I tapped the cylinder with a hammer and the key turned, Great . However, now I am having a problem trying to get the cylinder completely out of the column. It will slide out about an inch, should be any other type of release or just pull harder or What. Thanks.
Remove the plastic on top and bottom of the steering column. Under the key cylinder is a button you need to push to get the cylinder out. Check out YouTube videos for more details.
