XBoBJ
- Spencer MASS
do this take the front drive shaft out and try braking, will take 5 mins to do worth a shot, if it dont work Hasta me
dave92cherokee said:It sounds like it's a u joint problem in either the front or rear driveshaft. I had a problem similar to this not long ago where when braking for a stop sign at the bottom of a steep hill would sound like the engine was going to fall out. Crawled under the jeep and the front u joint in the rear driveshaft one lobe has lost almost all of the needle bearings and the lobe was almost completely chewed off allowing it to knock around inside the cap. Not saying this is the same as yours but would be a good starting point to check all the u joints in both drive shafts for ANY play or movement.
according to your lever selections, you have a NP231 tranfer case if originalPen_Two said:I have no idea what T-case it has. I just got it about 2 weeks ago. I just know I have a lever to slect 2H, 4H, N, and 4L.
