From what I have read, it is most likely piston slap but it sure sounds horrible. Im just under 210k and Im curious what is the right answer... Should I look into a rebuild or should I drive it till it stops running?
At an idle, it doesn't even sound bad but as the rpms increase, the knock gets louder and louder (it is not an exhaust leak). I used my stethascope and the #5 and 6 piston sound the loudest. I put in a new oil pump about 40k miles ago and the gauge shows 40 -50 all the time. This tick only developed about 5k miles ago but my wife doesn't want to even go anywhere in it now with out a bicycle in the back.
Any advice would be great, thank you.
Trav
Trav
