polar_jeep_04 said:thats why i said get adjustables so you can adjust the pinion until its where you are happy. im not trying to get you mad or tell you what to do im just trying to help
I know $ are a factor, BUT YOU are the one that want to at 5. personally unless your running 35's or 37's , there is no reason to be that high..ty20404 said:alright, i was just kind of hoping to hear from some other people on pinion angle vibes to see what other people have done about it, before I go out and buy adjustables.
and yes, adjustables are what i need, BUT, money doesn't always allow one to go out and buy whatever whenever. It drives fine right now, but adjustables are in the future.
lawsoncl said:A potentially silly question. Do the vibes go away if you pull the front shaft? Just trying to make sure you're vibes aren't from the rear which seems more sensitive to lifts as they are short in the XJ. While you have the shaft off take a good look at the u-joints. Used u-joints tend to wear out fast when you increase their angle. In the front, ideally the pinion is pointing at the xfer case but some misalignment is fine.
Despite doom&gloom iagreen, many folks are running 4.5 and 5" lifts in the front with nothing more than longer LCAs to keep the caster within the acceptable range. This includes me, btw.
ty20404 said:alright, so yes i do need longer control arms but the amount of caster that would be changed would be almost minimal...
A two inch BB never utilizes different control arms and the amount that the caster would be changed with a 2" seems as though it would be greater than my situation.
Anyways... Here is my question: Even for those of you that are running the appropriate control arm lengths for a 5" lift, do you not have any vibration coming from the front pinion/DS angle? I know for a fact that this is where my vibe is coming from and the angle visually looks to be in the 10 degree area... I know that having the appropriate control arm lengths wouldn't combat this problem. The vibe is too bad to drive w/ the DS on at highway speeds.
ty20404 said:Alright, so I'm sitting at about 5" of lift up front and I'm running LCAs for 4.5" of lift.
