GrimmJeeper
- Gardena, CA
its the steering its binding up on. the TRE at the pitman is maxed out before it gets anywhere near the full droop of those shocks. gotta go over the knuckle.
you gonna run a custom dash or the factory one?
haha his dash right now is non existent with the cluster tied up there. personally i would think custom cluster small and easy would be cool in this rig
yep. I'm going to build an aluminum dash once the cage goes in.
they're capped off for now the hoops are supported with legs that go down in the rear as well as the front. should be fine to drive out to the fest and back I won't be beating on it.
You have never wheeled with Mike, have you? haha
Somebody take his keys when he gets out there!!!! :laugh:
Looks great! If it were me and I was gonna wheel it before the cage is finished, I would probably atleast add another cross bar at the front of the engine (closer to where the shock are mounted). It will probably hold, but I know its hard to hold back sometimes once you hit the dirt!
