Are you using straight CO2 or a mix? - mastermix or another argon mix helps with splatter control - they can also affect the amount of penetration a smaller welder gets in thicker material
As noted dependable electical in feed is a big help - depending on where you were working the power grid can have a large amount of variation in voltage throughout the day - it is pretty amazing to take readings over a few days time several time a day...
Cleaning the base metal make a huge difference in repeatable strong welds - the sheilding gas can only do so much...
As for the technique problems I see a few - A. you have a cold start problem at the beginning of the uppermost weld (first pic) - B. also as you were driving along you seem to have lost track of the seam or stopped for some reason - starting with a gap and the quickly doubling back to alloy the cold weld material can help there...
At the bottom weld in the first picture it looks like either your stickout (distance from contact tip to workpiece) is slammed to the deck by the way the splatter is arranged or you have a shallow angle to the left and the splatter is kind of skipping out - the inside fillet weld is much easier to follow huh! - no issues with tracking there...
There is a small crater at the finish but not to much of a big deal - in aluminum that would be a bigger concern as it would be a stress riser - doubling back as you end the weld eliminates the problem (that brassy/tan material is actually molten silicon that has solidified)
The good thing is I don't see any under cutting (hard with such a small machine but still do-able) - The profile looks ok - not too peaked but not concave either - unfortunately as Beez said you need to see the back to see the temper zones to judge penetration
As for machine my favorite small machine is the miller 175 - it is about 650$ the prefered machine would be a miller 250 with a digital display - add a spool gun for Alum. and you are in the 1600 - 2000$ range...
The lincoln's are nice I have just never abused one like the millers...
Just my 2ct's
uke:
Matt
