Safari Ary
- Virginia Beach, VA
I want to push my front axle forward an inch or two when I do my long arms in the next couple of weeks. What I'm concerned about is rubbing the front of the inner fenderwell. I *think* that with the long arms the axle won't move forward as it compresses nearly as much with short arms, so it may not be a big concern. The reason I ask is because as it sits right now, I rub that area a good bit(enough to remove the paint after one wheelin trip). I will be extending my bumpstops when I put my new front axle in(stock right now with 4.5" springs), so this may solve some of my problems. Just trying to do some preliminary trouble shooting. Also, what sorts of problems can I expect from running hy-steer arms and the stock pitman arm(will this even work?). Thanks
Ary
Edit, the reason I want to do this is so that the coil sits directly over the axle tube. This will enable me to get a little funky with the trackbar. :greensmok
Ary
