jpcherokeekid
- north
So after i put my new aluminum radiator in i noticed that my underhood temps started to get really hot. my motor temp stays around 180 but the heat in the engine bay was getting way to hot. i could see it was starting to melt my air hose and plastic vacume lines. i also couldnt even hold my hood long enough to prop it up it was so hot. my vents i put on it a year ago are obviosly too small, and i put them in the wrong place, but regaurdless they dont work worth a crap. so i ordered my cowl induction scoop from summit, ($60), and cut about a 2ft square hole in the middle back part of my hood. now that i have a real hole for the hot air to vent out, i havent had any more problems with stuff melting in my engine bay. im going to fab up a small lip to go around the hole to keep running water out when it rains, but ill worry about that this fall.
