Before you spend $$$$ and not know where you are going with the build, buy
Performance Trends EA3.4 (or the older EA3.2) to model and research the relative output gained from the various combination of parts you are thinking about.
If you are not familiar with SCR, DCR, overlap, BSFC, valve sq-in degrees, fuel #/hr, and the difference between mild and wild cam ramp intensity, the engine analyzer will help you teach yourself.
You could also purchase
Internal-Combustion-Engine-Theory-Practice (volumes 1 & 2) for the same money and spend a year digesting the knowledge (with less favorable results).
Either method of modeling (computer modeling or old school calculations) will save you more than the cost of the education in parts and in knowing the parameters to have double checked during the machine work.
I wouldn't say the results from reading Taylor are "less favourable" than playing with EA (I've had EA, I have both volumes of Taylor, as well as many other "definitive" works on the four-stroke IC engine,) it really depends on how you learn.
If you have an academic tilt, the books will be just fine - easier to refer to, and you don't have to worry about transferring them to a new computer.
And, having both isn't bad - because you can learn it from the reading and see it in the sim, or see it in the sim and have it explained to you in the books.
I haven't compared the results with EA to the "real world," but engine sim programmes
are useful. However, it should be borne in mind that there's really no way to model for
all parasitic drag in the real world - when using a more low-buck engine sim (like, say, Desktop Dyno,) figure that real world results are going to be about 5% lower than sim results - the computer simulations can usually be taken to be "optimistic." Just
how optimistic depends on what model was used and how many variables were coded into the programme.
That being said, engine simulators are still useful for providing an "apples-to-apples" comparison of various parts swaps - key in all of the baseline data, and play around with cam profiles, for instance. You can still figure out a lot without turning a wrench! Just remember that the results are, indeed, going to be a bit better on the comp than in real life.
I've worked with EAPro - and I'd buy it, if I had enough spare nickels floating around (I need to buy something - upgrading to Win7 64 killed a number of my legacy apps.)
Taylor, Blair, Richardo,
et al all do make for some heavy reading - if you're not ready to try to figure out what they're talking about, you may find it too much. Problem is going to be trying to find these books at a library - I bought them because I couldn't find them anywhere around here (and even that took some doing to get them for a more reasonable price on eBay - considering the sort of pricing you'll see from MIT Press or SAE Press...) Bentley Publishing, as I recall, has some good books on IC engine theory - that are a bit closer to layman's terms and cost a good deal less. You may want to peruse their site as well.
@CJR - do you have any pix of your sectioned heads? I want to do something similar with 6-242 heads (I've got a 2685, 2686, and 0630 head so far - need at least one 7120 and 0331. I also want to be able to save a cylinder section for porting experiments...) and I'd like to accumulate as much data as possible.
