- Hartsville, South Carolina
When I ran the D44 with high steer I had problems with the xj drop pitman arm being too short and loosing turning radius. Research indicates SJ arm to be ideal. I think some of you are runnign this arm. I have one and it works but the castle nut contacts the lip of the frame that bends down. I have located a new, read expensive $$$$, CJ drop pitman arm for the 72-75 that is the same bolt hole to bolt hole. Question is are there any other known arms that will work that are cheaper? The CJ arm has a bolt hole to bolt hole distance of 6".
