MAP
- Wilmington, California
Just a little extra on this. My sister's car had an overheating problem where it would only happen at speed. At idle it would cool just fine.
Well the problem was the impeller on the water pump. It was made of plastic and had broken. At idle there was enough coolant circulation to cool the engine but at speed the fluid was just not circulating enough through the system to cool down the engine.
So if you're having that issue, I would check the water pump.
Maybe I'm mistaken but I believe I read somewhere that the 97+ XJs have plastic impellers. Someone here probably knows if this is true or not.
MAP
MAP
