Ok sorry it took me so long to reply, so far ive got new shocks, fixed the crack, and its the stock track bar with a drop on the axle, the control arms are fixed and give it slight but equal caster with no drop, ok im starting to think its not the front, fixed eveything or upgraded everything up there, u-joints, sterring, new track bar, bushings, has drop pitman arm, hub assemblies, even checked calapers, alignment, wheels balanced, everything is tight and greased. They said the wheels were slightly bent but would be ok with weights but im still going to try a differnt set, I have the peogot tranny that im getting rid of but the mount is really worn could that couse some kind of vibration to couse wobble, and what is the better tranny to straight swap in there, im collecting parts to have a ford 8.8 rear with slip yoke elliminator and a dana 44 g2 in front is there anything bad in running that set up, does it matter the 8.8 is like 3/4 in shorter, it seems like it never ends i just want to go on a high way again.
