Haha nice but no. The flush must of helped it because later on when I went out it began working. Its not hot but its warm enough, but like I said I still need to figure out why its only blowing out on my feet. Still though better then it was before. The warmer weather is nice though.
A little update. Yesterday my wife had car trouble so while I was getting her back on her way the cherokee was running for about an hour, to my surprise it was blowing hot heat and kept the inside nice and warm despite it being in the low 30's and sleeting. So I now believe that maybe the Thermostat is stuck open (defective). If you recall the thermostat was the first thing I changed. I used a Stant 195 degree thermostat (the lower end stant not premium). I also heard that if the thermostat is installed backwards it will stay open, well I installed it the same way the one I took out was (I believe the spring section went in to the block). Is that the correct way? Should I go to a 210 degree to help warm the engine quicker?
Yeah, stick with the 195 stock. The older systems (aka closed) needed a bleed hole to be drilled (or some came that way?) to let the air out. Newer systems don't need the bleed. Some people believe that they have gotten air pockets out of the newer ones by squeezing the upper radiator hose.
