I just went through this on a 1990. I had the same problem, luke warm at best - hardly any heat when it was below 20 degrees outside. I had to replace the heater core. I also found a lot of debris in the heater door hinge area, including a screw that was (possibly) binding the door up - but that had nothing to do with the lack of hot air, the core was clogged up beyond Prestone's abilities.
Search here, there is a good write up with pics for the core - (changing the core isnt the problem, getting the air box out and back in is)
mixer door junk is here; I apologize for the ranting, I was an unhappy monkey
http://www.naxja.org/forum/showthread.php?t=1020640
