mojojojo
- Gresham, Oregon
WaXJ_Skier said:do your turn signals work?
yes.
no parking lights, headlights, high beams though.
Blkxjkrawler said:Wiring diagrams flow from the top down, so start at the fuse and go down. My bet is that you will find that fuse link blown. Basically the fuse link supplies power to the headlamp switch, and the foglamp switch. When the HL switch is turned on it sends power to the dimmer switch for the high beams, and also to the fog lamp switch. activating the foglamp switch provides power to the fog lamp relay coil, which then closes the relay contacts and allows power from the fuse link to flow to the fog lamps. Confused yet?
without that fuse link you will not have High or low beam headlamps, park lamps, or fog lamps,
turns, and brakes would funtion normally since they are on a different circuit
bcmaxx said:If you need I can get a picture tommarow morning
mojojojo said:a silver box with a crapload of wires going to it. i assume this is the distribution thing? quote]
That is the power distribution think. The red and green wires coming off of it are the fuseable links. grab one at a time at both ends and pull, if the insolation streaches then there you go. b urned out link.
Hope this helps,
Pigpen
