Highway driving is bad. 70. Is Max any more and it will run hot. Coolant is maybe a resivour full every 500-800. Not been paying to much attention.
Before the new radiator went it I flushed the block and heater core. Then did water pump and tsat after, so the block it flushed as much as possible. I know these rigs suck at maintaining engine temp. But I'm not asking it to do anything extrodinary here.
Rig is a 94 168k aw4 bout 5 iinchs lift with 33 4.56. stand alone b&m cooler stacked plate style,. Biggest that will fit in front of mechanical fan. With same cooler for ps. Radiator trans cooler not plumbed.
Ac works great.
I know this is an old thread, but I wanted to ask if the engine has had the head gasket replaced prior to the overheating issues. I've run into a problem where I overheat on the highway after replacing my head gasket after a valve job. The new FlePro gasket is missing all of the water port holes down the length of the gasket. Maybe driving around town this is fine, but on the highway going up hill or going 75mph plus it starts to heat creep. Everything is new and checks out. The only thing left is the head gasket missing the water port holes. And yes, both the head and block have the holes where the factory head gasket had the holes on it. So my last step is to do what some shops apparently doing and to drill out the holes in the head gasket. I think at higher rpms it is hindering the cooling of the cylinder head and overheating the engine.
